49 Ford F1 7HT carburetor Replacement Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2008, 09:03 AM
Well I cant get a good original 7ht carburetor rebuild
I do have a 49 Ford F1 with the original 6 CY 226 engine and with 1 bbl
with the old oil pam filter on top. many problems with leaking or so.
The truck does have a eletric fuel pump installed by the previows owner.
I would like to change to something modern , Maybe Holey , dev , who knows ?
any one can help with sugestions??
thank you very much
Sb
Roxbury CT
Old 07-23-2008, 06:41 AM
theccrider's Avatar
always proceed, go forward
I would look for something from offenhauser to adapt, they have a pretty complete array of adapters. the last I used from them was to adapt 97s to a corvair motor in a vw bus.
hope it helps, check speedway
SBC header fit in Ford F1 lelshaddai Engine 1 07-12-2008 08:22 PM
Amazing Discovery about Ford F1 Gauges. lakota Hotrodding Basics 6 12-19-2007 12:44 AM
1951 Ford f1 front end n00b Suspension - Brakes - Steering 5 09-09-2007 09:48 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
49 Ford??? Weimer Hotrodders' Lounge 17 10-12-2002 05:19 PM
