49 ford motor mounts - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2006, 08:33 PM
Hi folks,,I`ve got a 49 ford tudor "6", want to put a 255 flatty in it. Is there going to be any problems with mounts, or anything else? Thanks WeeWilly..
Old 04-11-2006, 09:16 PM
Max Keith's Avatar
engine swap
The only thing you need to do is get the proper engine and frame mounts for the Flathead V-8. I dont remember about whether there is a difference in the bellhousings and flywheels. The best thing to do is to find a web site specializing in Flathead V-8 parts or buildups and contact them. I havent worked on a flathead since the mid 60's, so Ive forgotten a lot of stuff about them.
Old 04-11-2006, 10:17 PM
junkyardjeff's Avatar
The holes in the frame should be there so you only need to do is find the mounts for the V8,you will need the V8 radiator too. The sixes had the radiator mounted in front of the core support and only two outlets unlike the V8 that has four. Jeff
Old 04-11-2006, 10:23 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Check with Flathead Jack for the stuff you need. You will need a radiator, four hoses, motor mounts and brackets, and I am not sure what else. www.flatheadjack.com
Ford vs Chevy question savman1 Engine 31 10-14-2008 08:13 PM
49 ford walt hennig Suspension - Brakes - Steering 4 11-05-2005 08:47 AM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 05:18 PM
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
T-5 transmission codes needed xntrik Transmission - Rearend 4 09-06-2005 10:09 PM
