Does the 49 Ford have parallel leafs springs? If so find a rearend that is the same length has what you have and you should be able to get it in, you might have to change the mounting pads, or the shock mounts, but then there is not much that will fit right in with out some work. If you want it so you take things off this to put on that, you are in the wrong hobby.
"well nut I see the New Year has not changed you any for the good :nono: :nono:" ?????????
Are you serious?? cuzz I sure wasn't, I guess my brand of humor didn't register with you. It was just a comeback in regards to the OP's "that was not much help" reply to you.......again, geeeez
Mustange rear end is a good choice, there are a lot of them to be found out in wrecking yards, on the internet, or around your neighborhood. in my opinion unless you are going to go all-out raceing dont worry about if it is a 9" or an 8", possi. or not just use what you get, and enjoy the ride put some miles on that ford along with a smile on your face
have a good day-----lowmerc
i ended up with 2wd s10. fit good but had to use rear end spacers.
i did find that 2 and 4 wheel drive are different widths. 4 wheel drive is way to wide
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
