49 ford sedan rear end upgrade question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2011, 07:38 PM
im looking to up grade my 49 2 door ford sedan rear end..what rear ends will bolt in place with little to no mods..thanks
Old 01-01-2012, 05:36 PM
35terraplane's Avatar
Rearend upgrade
Does the 49 Ford have parallel leafs springs? If so find a rearend that is the same length has what you have and you should be able to get it in, you might have to change the mounting pads, or the shock mounts, but then there is not much that will fit right in with out some work. If you want it so you take things off this to put on that, you are in the wrong hobby.
Bob
Old 01-01-2012, 09:17 PM
49 ford
that was not much help..
but i did find the 65/66 mustang bolts right in..
thanks
Old 01-01-2012, 09:43 PM
327NUT's Avatar
Yea terraplane, whats wrong with you ???....why didn't you just give the correct make, year, model and part number......geeeeez!
Old 01-02-2012, 02:56 PM
Rearend
Well nut I see the New Year has not changed you any for the good.
I do have a sheet with all the Ford rearend lengths, but I couldn't find it, And I guess I just can't remember all of them.
I guess he would want someone to come over and put it in for him, or even go to the yard and check the size.
But then I didn't see anything that you added that was worth a damn.
Well I guess a mustang works. Job almost done.
Bob
Old 01-02-2012, 04:42 PM
327NUT's Avatar
"well nut I see the New Year has not changed you any for the good " ?????????
Are you serious?? cuzz I sure wasn't, I guess my brand of humor didn't register with you. It was just a comeback in regards to the OP's "that was not much help" reply to you.......again, geeeez
Old 01-03-2012, 10:33 AM
Sorry Nut, I didn't feel good and just read it wrong, my bad.
Bob
Old 01-05-2012, 01:46 PM
49 ford rear end up grade
Mustange rear end is a good choice, there are a lot of them to be found out in wrecking yards, on the internet, or around your neighborhood. in my opinion unless you are going to go all-out raceing dont worry about if it is a 9" or an 8", possi. or not just use what you get, and enjoy the ride put some miles on that ford along with a smile on your face
have a good day-----lowmerc
`39 Ply sedan,I need some upgrade info Elwood_DR Introduce Yourself 1 10-11-2010 10:34 AM
Ford 9" disc brake upgrade question bebopwally Suspension - Brakes - Steering 3 07-04-2010 03:49 AM
48 ford sedan rear end swap Bstrang Transmission - Rearend 4 09-11-2009 08:15 PM
57 Ford f100 rear spring upgrade hotrod66_57 Suspension - Brakes - Steering 0 05-19-2009 04:42 PM
Wiper Set Up 35 Ford Tduor Sedan Question ratfink35 General Rodding Tech 6 01-23-2008 01:22 PM
