49 plymouth questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2009, 02:27 PM
hi...i have a 49 plymouth 4dr sedan special deluxe
what are the current factory suspension, brakes, and steering like?
are there modern parts from salvage, autorecyclers, or affordable quality aftermarket pieces that will swap right in???
thanks...
Old 06-16-2009, 02:41 PM
48ChryslerRodder's Avatar
Stuck in the past.
This post came up yesterday and has links in my response that may help you out.
drum to disc conversion
Old 06-16-2009, 04:29 PM
I would suggest visiting the P15-D24 forum, where you will find a wealth of information about your car.
Some will disagree, but your car has IFS, a stout frame, and if it's in good shape, shouldn't be a problem.
The brakes, however, are a different story. I wouldn't waste my time or money rebuilding the original brakes. They were poor, at their best. But there are disc brake kits available for these cars, that use mostly off the shelf components, readily available.
There are also power steering conversions available for them. Good luck with your project...there are many more Fords & Chevies out there, but old Mopars seem to be more prevalent this year at the car shows.
Old 06-16-2009, 07:29 PM
thanks for the link, it is helpful!
Old 06-16-2009, 07:37 PM
thank you...that is some good food for thought. i found a front conversion kit but not a back. i will definitely want power steering!
49 chevy fleetline dj153727 Introduce Yourself 3 01-21-2008 06:31 PM
1932 Plymouth T. Darrell Introduce Yourself 4 12-15-2005 02:54 PM
49 Plymouth Club Coup John Endresen Introduce Yourself 1 01-04-2005 05:11 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 05:15 PM
