49 truck on 66 frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2006, 11:06 AM
Hi, I was wondering if anyone out there has built a 49-51 chevy 1/2 ton truck on a 66 chevy truck frame. I'am building that combo. If so, I would like to know what problems I might have. Thank you , Truck guy
Old 01-13-2006, 05:48 PM
85GMCguy's Avatar
I haven't heard of that particular combination, though I did set up a 77 Chevy truck frame for a 64 International Harvester pickup body. Talk about fun...
Have you measured track (axle) width and wheelbase? I've noticed that a lot of older trucks fit nicely on S-10 frames. As long as you're prepared to do a lot of fabrication, nothing is impossible. Another alternative would be to do a front clip graft. Just a thought. Good Luck, and remember- measure twice, cut once
Old 01-14-2006, 09:42 PM
Hi, thanks for replying. I bought this combo as a work in progress! The rear frame was "c" notched, springs cut, and running board brackets mounted to the frame, cab on. I bolted in an 83 front clip and rebuilt the frontend with a polygraphite kit. I temporarily bolted the sheet metal (fenders, hood,running boards) looks ok so far. I have since, cut the front springs 1 1/2", mounted a rear shock relocater kit and have a ajustable panard bar. It sits low but not too much. Yes, no one seems to have this combo. I have gone far, I do not want to start over! Happy Rodding, truckguy
Old 01-14-2006, 10:25 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Interesting...
I have done much the same front clip swap as you have, but the frame will be going back under my 66.
The front-clip / steering swap was pretty easy ... especially after buying a REZ power steering bracket kit. I can't wait to drive that truck with power steering, power brakes, and well ... just plain POWER.
I've also discovered that the 1-1/4" sway bar from a 1979 C20 is pretty much a bolt-on ... I'm hoping it will help stiffen things up a bit, as I'm putting a 454 in there as well.
Have a look at my project journal if you like. I've just updated it with pics of the sway bar installation.
Working on a 1954 Chevy truck, frame off MRH1999 Introduce Yourself 2 08-15-2005 11:31 AM
51 f-100 ford truck frame short dude 91 Hotrodding Basics 5 06-08-2005 04:33 PM
EL Glow gauges for my '49 Chevy Truck hiimed Electrical 2 04-15-2004 02:28 PM
c4 suspension on 49 chevy truck ls1cobra Suspension - Brakes - Steering 5 12-17-2003 09:36 AM
49 chevy pickup on s-10 frame gasNgo Suspension - Brakes - Steering 2 12-17-2002 07:11 AM
