496 aluminum head choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2012, 06:13 AM
plenty of heads out there..
.650 lift hyd roller
800-950cfm carb
dual plane intake
nothing over 6000-6500 rpms
2500 stall t400
heavy 4000lb vehicle
4:11 tearing
looking for torque
been doing research, AFR's look good, edelbrock RPM's look good, patriots are priced right..
got about $2500 for heads
any suggestions?
Old 06-17-2012, 07:10 AM
BOBCRMAN@aol.com's Avatar
Pro-Comp or Patriot heads, 280-290 runner oval port (actually a shorter rect port) are very good heads and will do the job for less money. Pay attention to correct spring pressures and push rod lengths.
I have sold/used these heads for years and had NO problems.
Old 06-17-2012, 07:28 AM
http://www.superchevy.com/technical/...d/viewall.html
Super Chevy did a build with patriot heads a few years ago.
decent numbers on the dyno..
Old 06-17-2012, 07:03 PM
if you have the buget for them.. the AFR 290 CNC heads would be a perfect combo...
Old 06-17-2012, 08:13 PM
i am currently sitting in kabul afghan, so another 500 bucks for head budget is no big deal..lol
and 500 extra for full CNC porting, that's pretty amazing..
$2,910.97 is what their showing on the AFR site..
they have 2 models one that'll take .650 lift and one that'll take .850 lift.
Old 06-17-2012, 09:49 PM
Well First and fore most THANK YOU FOR YOUR SEVICE!!! Its not easy in the middle east for sure.. I too have a few family members still serving, one just was redeployied on the USS Rosivelt aircraft carrier. Back to he heads.. If you have a specific cam you are wanting to run and you decide to buy the AFR heads, send AFR an email notfying them of what cam you have and they can set you up.. The valve springs they advertize may not work for you specfically, so best to contact them...Your best to spend more of your budget on heads and a good cam...thats where you gain the most...
which head and cam combo to use 496 bbc slicknova72 Engine 0 02-20-2011 06:54 PM
Aluminum cylinder head choice. Biscuit6447 Engine 6 10-24-2009 01:13 AM
bbc 496 head? tsmall114 Engine 27 10-09-2009 06:38 AM
head choice??? ssonny34@yahoo.com Engine 12 05-14-2009 06:58 AM
help with head choice bamacj Engine 4 11-04-2003 04:22 PM
