496 BBC buildup - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2007, 05:04 PM
496 BBC buildup
Do big block chevy engines have oil slingers between crank gear and balancer, my 83 454 block did not when I tor it down for machining, how imprtant are they? should I get one or dont worry about it?? I've got a dble roller timing set and high volume oil pump w/stock spring. thanks all
Old 08-14-2007, 05:34 PM
Bumpstick's Avatar
Hammer and a torch
No the slingers have not been used since the 283`s and earlier...
Old 08-14-2007, 06:56 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
What Bumpstick said. No slinger used.
Sould I build 496 or 468 BBC?? Help. MuscleBlock81 Engine 11 09-09-2009 03:14 AM
496 BBC buildup BBstroker Engine 3 04-12-2007 09:14 PM
496 BBC buildup BBstroker Engine 2 04-12-2007 03:40 PM
496 BBC buildup BBstroker Engine 2 04-11-2007 08:53 PM
BBC 496 or 525 sb72elcamino350 Engine 2 10-20-2004 10:40 AM
