496 build.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2007, 12:26 PM
496 build..
i have a 454 block, 2 bolt main, what all is needed to be done to the block to make it a 496? i am gettin a 4.250 crank, does there need to be clearencing in the block to fit the crank? does the rod's need to be longer? thank's
Old 07-07-2007, 01:38 PM
techinspector1's Avatar
Wiki Edits: 326
I'm not a BBC motorhead, just SBC, but I'll try to get you started until someone comes along with better answers for you. The 496 uses a 4.310" bore (0.060"-over) and 4.250" stroke crank. You can use stock length (6.135") rods or you can use longer rods. It all depends on your piston choice. A piston for use with the stock length 6.135" rod would have a compression height of 1.520". A piston for use with a 6.385" rod (+0.250" longer than stock) would have a compression height of 1.270".
I suspect it's like every other build as far as clearancing. Every block is different.
You might do a little reading before you begin to lay down the long green for parts to make this work. Here's a good starting place......
http://www.themotorbookstore.com/chevy-454-manual.html
Old 07-13-2007, 12:46 AM
Cool thread-im hoping this will be updated with lots of information.
I myself am an absolute noob to american engines after numerous quick riceburners (current car is a TT mk4 supra but am planning c3 vette purchase)
Not sure if i should start a new thread for this or not- i guess its all kinda relevant.
When fitting a stroker crank to a stock 454 (to make a 496) what does the CR end up being roughly when using stock pistons and rods.
If building a blown 496 with low CR and new internals- do you alter head capacity, rod length, piston size or all 3? With the 2J its as simple as just ordering pistons to suit your CR.
Hope everyone is having/had a good day :-)
-Nathan
Old 07-13-2007, 06:15 AM
I have a 454 .60 over bore and I plann on going to a 496 as well maybe even a 502. I have spoken with the performance shop and they told me I will not have to to anything to the block to to to a 496. To be able find out for sure if you have to have work done to you block first I would say to take it in to a machine shop or at least ask about that cast number if the block is virgin then they should be able to help you.
Old 07-13-2007, 09:38 AM
Bumpstick's Avatar
Hammer and a torch
Block will be fine but be sure to get a stroker pan for it... The stock type pan or even aftermarket stock rail pans will interfear... The stroker pan has a different stampinp of the rail where it bolts to the block...
Old 07-17-2007, 12:32 PM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Hey Gents, I would like to out my two cents in here. I just finished building a 496 a couple of weeks ago and here are some things that I found that contradict some statements made here.
1. If using a GM Block you will need to clearance the block on the sides if you are using a 4.25 crank and any kind of decent rod. The rod bolts won't clear the sides of the block. ARP sells low profile 7/16 rod bolts to reduce the amount you have to grind. You will also have to clearance on the bottom of the cylinder bores a little no matter what.
2. You have to purchase pistons with short skirts if you are using a 6.135 length rod. If you use a 6.385, or 6.535 rods you won't have a problem because the pistons that have the appropriate compression height are usually short skirt pistons. The pistons skirts will hit on the counterweights on the crank when the pistons are at the bottom of the stroke.
3. Most Aftermarket pans for BBC's accept up to a 4.25 crank, but that doesn't mean you will be able to fit a windage tray in there as well.
D. Make sure you find someone who has done what they are talking about before and can prove it before you take their word...I didn't and ended up learning the hard way on a couple of things.
Old 07-17-2007, 12:34 PM
Double_v23's Avatar
Here are some pictures of the clearancing
ID:	22794   Click image for larger version
Here's where I'm at with my 383 build Malibu73 Engine 17 12-06-2009 09:56 PM
build a moter or buy a car first? Tryin2MakeIt Engine 19 12-13-2006 10:43 PM
Battle of the Strokers: 383 vs. 496 - cast your vote now! Malibu73 Engine 36 11-30-2006 08:53 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 02:48 PM
496 build up >>> NEED ADVICE terror385 Engine 5 11-17-2003 09:42 AM
