496 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 09:56 PM
496 build
I would like some opinions on using a MLS .020 head gaskets. I am building a 491 BBC with Edelbrock Performer RPM 118cc heads. Bore: 4.290 Stroke: 4.250. I have an Eagle Pro Series kit: 4340 steel crank, Icon #789 forged pistons 10.2:1, 6.385 H-Beam rods, Clevite bearings, Mahle ring set. Victor JR intake and a Holley 850 DP The cam I am using is a Crower mechanical roller #01485. Adv duration intake 296/302 and adv lift is 641/636. At .050 duration is 256/266 and lift is .377/.374. The lobe separation is 107* 103* intake C/L for lobe center method. Assembled the pistons are .025 from the top of deck. (stock deck height) and with the recommended head gasket 1017-1 .039 comp thickness the quench is .064. I want .045-.050. i can use a Cometic .027 head gasket which would still give me .052. The motor is going in a 67 Camaro with 400 auto transmission, rebuilt 12 bolt GM rear 4.11 gears, solid alum frame bushings, frame connectors, and Caltracs; 3400-3500Lb body. Something to mess with at the track on weekends. I want some opinions on using .020 steel shim head gaskets. I especially want to hear from techinspector1 on my setup. I like his analysis on motors. Thanks Doug
Old 01-15-2012, 11:04 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
No reason you can't run the MLS gaskets, as long as you're piston to valve clearance is there and your heads and deck are flat.
Semper Fi
355 build??'s about compression and build impalaman355 Engine 5 06-06-2011 10:20 AM
New guy wants to build hp! drelotter Engine 54 07-30-2009 04:12 PM
355 build need help BIGWISEXY Engine 2 07-19-2009 09:26 AM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 09:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
