496 horsepower? Guess? Should have dyno sheet Monday. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2014, 01:53 PM
Building a 496. Block is 2 bolt, scat steel crank, internal balanced, probe forged 18cc domes, H beams, 781 heads, pocket ported, cleaned up and shaved a little, air gap intake, 850 demon, All MSD elecs, CAM= hyd roller Comp 11-450-8: 290 dur 578 lift. Guess at the HP AND TRQ and Ill post the results. Thanks!
Old 02-26-2014, 06:28 PM
Proud LOSER
I'm gonna go with the double nickel
500/500
Old 02-26-2014, 08:07 PM
I was hoping for more, but could live with that.
Old 02-26-2014, 10:08 PM
vinniekq2's Avatar
what size valves? what size headers.Is the demon a known wel working carb? what is the actual compression ratio?
Old 02-26-2014, 10:31 PM
vinniekq2's Avatar
My guess is 475 HP and 550 pounds torque
Old 02-27-2014, 12:19 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Why not use the HP calculator link at the top of this forum on the main page?
Semper Fi
Old 02-27-2014, 09:44 AM
Valves are 219-188, 1 7/8 headers, 10.5 comp
Old 02-27-2014, 11:31 AM
OLNOLAN's Avatar
Just for bench racing fun
I think the heads may be the choke on that many cubic inches.
Here's my GUESStimate; Hp=545-585 somewhere between 5500-6000rpm. Torque= 565-600 somewhere between 3000-4500.
Something gives me a feeling the dyno results are gonna surprise us. Oh, if I win, I want a new hat to wear while I change the oil in my old ones.
Nolan
The Following User Says Thank You to OLNOLAN For This Useful Post:
C10 496 (03-16-2014)
Old 02-27-2014, 10:03 PM
vinniekq2's Avatar
with 2.19/1.88 valves and a good porting job,the engine could make 550 hp,with out flow numbers its just a wild guess.
headers are too small, I use 1 7/8 stepped 2 inch on my sbc
Old 03-05-2014, 08:42 PM
Looks like next Monday now. Shop is 1 man down. (sick)
Old 03-05-2014, 09:17 PM
Banned
505hp/568ftlb
how high you going to rpm this.. I'm assuming that the crank is cast as you said steel not forged..
450ftlb+ from 3400 up
that extra arm and 2 bolts, you did use arp studs
Old 03-05-2014, 09:27 PM
Banned
why you think the headers are to small..
it's a long arm 2 bolt block.. (guessing ) cast crank..and hyd cam.. it's not rpm'n to the moon.. I'm not sure I'd go over 5500 many times.. if indeed it's a cast steel crank.. and 2 bolt block with bolts not studs..
that's a long arm to swing with 2 bolt mains.. and rpm
The Following User Says Thank You to gearheadslife For This Useful Post:
Old 03-06-2014, 07:33 AM
It is a 4340 steel crank. Not over 6000 rpm. and studs.
The Following User Says Thank You to C10 496 For This Useful Post:
gearheadslife (03-06-2014)
Old 03-16-2014, 07:40 PM
It made 583hp, 626 lbs. Now I need to get it to hook! Hoping caltracs with the overloads removed will do the trick.
Old 03-16-2014, 07:59 PM
vinniekq2's Avatar
makes more torque than my small block,nice.
post the dyno sheets
your heads were better prepared than you lead us to believe
The Following User Says Thank You to vinniekq2 For This Useful Post:
73gremlin (03-19-2014)
horsepower guess? rebel101150 Hotrodding Basics 30 01-07-2013 03:36 AM
Horsepower guess!! please 1fast62 Hotrodding Basics 12 05-24-2011 12:51 PM
Guess my horsepower swoodard23 Engine 16 08-17-2007 06:14 PM
hp guess, anyone with a pc dyno dejo Engine 14 11-22-2006 04:49 PM
Can anybody guess what my horsepower might be?? Robbie Engine 4 02-08-2004 08:40 PM
