There is no way nobody here can tell you what the power level will be, the info you give is far too sketchy.
Complete cam profile is needed, lift, duration, etc. Compression ratio. Head flow numbers. Which carb? Dominator? With the little info we have trying to tell you the power it makes would be shooting in the dark. |
Took me a bit. I decided to go with a diff set up. Still a 496 though-Compression 10.4:1- Heads 320cc 2.250-1.880-Manifold Elde air gap rect port-Cam Comp Thumper Hydraulic flat tappet
Basic Operating RPM Range 2,000-5,900 Intake Duration at 050 inch Lift 235 Exhaust Duration at 050 inch Lift 249 Duration at 050 inch Lift 235 int./249 exh. Advertised Intake Duration 287 Advertised Exhaust Duration 304 Advertised Duration 287 int./304 exh. Valve Lift with Factory Rocker Arm Ratio 0.510 int./0.495 exh. Lobe Separation (degrees) 107 Quick fuel 750 |
. Perfect Grocery getter!
396chevelle,
Install C-clip eliminators in the diff. Use the 400 trans. Install an SFI-legal driveshaft loop within 6" of the front universal joint. Any further back will be illegal. Can be welded in or bolted in, your choice. 360 degree loops are used because you don't know which way the driveshaft will go when the joint breaks. They have been known to auger up through the floor and attack the driver's or passenger's hip and leg. Normally on this type of forum, the main group of participants will be 50-60 years old, with lesser numbers of both younger and older enthusiasts filling up the board. Us older guys grew up when you had to have the knowledge to do stuff yourself. Many of us didn't have access to sophisicated machinery or techniques, so we fixed 'em and modified 'em until we achieved the performance increases we were seeking. We passed knowledge among ourselves about what components worked better. If a certain camshaft made power in the range where we needed it, then that's the cam we ran. It didn't matter much whether it was lumpy or not, that was not one of the considerations to choosing a camshaft back then. We were hotrodders looking for the quickest and fastest combination. Today, you can build a complete car from scratch with a credit card and the youngsters seem to care more about what the cam sounds like rather than using a cam that makes the most power in a range where you can use it. That sort of makes us old guys feel like some of you current generation of rodders are posers instead of enthusiasts. Maybe we should identify another class of competition, Poserod. You guys could have a idling competition. Winner gets a kiss from the Poserod Queen, Jeff, a cheezy trophy and a box of candy bars. |
This is a forum that you can get advice from right?
ouch!
1234567 ... There. That should satisfy the 10-character rule. |
| ls-7 454 cam opinions | bamacj | Engine | 8 | 01-14-2007 07:30 PM |
| Opinions please | oldster | Engine | 11 | 04-05-2006 12:38 PM |
| I would like some opinions.... | Turbo Terror | Engine | 5 | 02-15-2006 11:39 AM |
| opinions | WakBordr7387 | Hot Rod Art | 13 | 02-02-2006 08:52 PM |
| Need opinions please | Jag Daddy | General Rodding Tech | 5 | 03-12-2004 02:52 PM |
