-   -   4l60 and 4l60e (http://www.hotrodders.com/forum/4l60-4l60e-226945.html)
jjhaithcote 12-08-2012 11:07 AM
4l60 and 4l60e
I have a 1994 k2500 5.7 liter 4x4 with a 4l60. Transmission is bad. Got a used tranny from local junk yard.It's a 4l60e. These two transmission are different.Will the 4l60e work in my truck?
123pugsy 12-08-2012 11:21 AM
Your truck originally came with a 4L60e. Was it swapped out to a 4L60 (700r4)?
jjhaithcote 12-08-2012 12:25 PM
called dealer gave them the vin and they said it came with 4L60 not 4L60E
123pugsy 12-08-2012 12:44 PM
If it has a square 4 pin connector on it, its a 4L60. If it has a round connector with a bunch (17?) pins, its a 4l60e.
Sorry, if I'm contradicting what the dealer says. I'm sure they're always correct. :rolleyes:
jjhaithcote 12-08-2012 12:50 PM
Truck has a shift linkage and used transmission has a shift cable. the 4L60E also uses an
digital dash.My gauges are analog
jjhaithcote 12-08-2012 12:57 PM
transmission in truck is a 4L80E
123pugsy 12-08-2012 01:03 PM
I should have figured that out since it a 2500.
Hope you can get your money back.
