4l60 and 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2012, 10:07 AM
4l60 and 4l60e
I have a 1994 k2500 5.7 liter 4x4 with a 4l60. Transmission is bad. Got a used tranny from local junk yard.It's a 4l60e. These two transmission are different.Will the 4l60e work in my truck?
Old 12-08-2012, 10:21 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Your truck originally came with a 4L60e. Was it swapped out to a 4L60 (700r4)?
Old 12-08-2012, 11:25 AM
called dealer gave them the vin and they said it came with 4L60 not 4L60E
Old 12-08-2012, 11:44 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
If it has a square 4 pin connector on it, its a 4L60. If it has a round connector with a bunch (17?) pins, its a 4l60e.
Sorry, if I'm contradicting what the dealer says. I'm sure they're always correct.
Old 12-08-2012, 11:50 AM
Truck has a shift linkage and used transmission has a shift cable. the 4L60E also uses an
digital dash.My gauges are analog
Old 12-08-2012, 11:57 AM
transmission in truck is a 4L80E
Old 12-08-2012, 12:03 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
I should have figured that out since it a 2500.
Hope you can get your money back.
700r4/4l60/4l60e? musclecarsrock68 Transmission - Rearend 10 07-18-2011 02:09 PM
4L60 to 4L60E lpvff_2006 Transmission - Rearend 3 12-02-2007 08:28 PM
700r4 , 4l60 , 4l60e propaneburner Transmission - Rearend 2 01-10-2006 02:32 PM
4l60, Or 4l60e 1994 Gmc 4wd buddy powell Transmission - Rearend 4 10-14-2004 06:16 AM
700R4/4L60/4L60E (long) HotRod55man Transmission - Rearend 10 10-12-2004 10:20 PM
