4l60-e GMC Trans problems
I have a 4l60-e gmc tranny and it works fine until you drive for awhile or are driving about 60 for ashort period. You stop and when you start again upshifts are hard almost slamming into gear. Funny thing if you stop at the next light turn off the truck for a few seconds then restart it and go again, it shifts fine for awhile again?????
Mileage on this trans? Any recent work or fluid service work? Is the check engine light on? Any vibration , or engine mis-fire? Or something that may feel like that when you cycle the ignition key off , then re-start the PCM is reset possibly from a DTC , so the trans works well till the PCM sees a problem again. I would suggest a scan of the system with a proper scanner, not a code reader. A code reader may pull some codes out that are useful
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Be assured this needs to be looked at, hard shifts will eventually start breaking expensive internal parts. Is the Check Engine Light coming on? Codes may help narrow where the failure originates. Bogie |
| 1985 GMC 4WD trans swap | bvnseven | Transmission - Rearend | 1 | 02-06-2010 07:59 AM |
| 81 trans am starting problems | stoney 81ta | Engine | 4 | 08-13-2009 07:36 AM |
| 99 GMC Sonoma, 2.2L 4L60E problems | mkhurley | Transmission - Rearend | 4 | 12-20-2008 04:53 PM |
| 1986 GMC with t-350C problems | twillmott | Transmission - Rearend | 3 | 03-25-2007 10:07 PM |
| 96 GMC Jimmy Trans | Neil B | Transmission - Rearend | 3 | 10-10-2006 04:34 PM |
