4l60 e no 3rd or 4th - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2011, 07:38 AM
Beerman28
I have an 04 silverado, that wont shift out of 2nd. It had hard shifting problems for a couple months, and then one day it just wouldnt shift. I talked to several people who led me to believe my 3rd and 4th clutches were fried. i have a degree as an automotive tech, but persued another field after college. At any rate auto transmissions were never my strong point. I dont have the money to pay some one to rebuild it, so im going to have to try it my self. I did rebuild a few while in school, but thats been 5 plus years. Im open to any tips, pointers, suggestions, ect.... also ive heard a little about upgrades but not sure ecxatly what they were talking about, so if theres anything there i should know about i would be grateful for any advice there as well.
Old 12-26-2011, 11:34 AM
You really need to hook it up to a scanner and see what kind of codes it's throwing. Don't assume the worst until you're sure what's going on, I bought my pickup for scrap price because the owner was convinced (not by me) that it needed a new tranny. It had 3 wires in the loom shorting against each other, a little tape and it runs like a top.
Old 12-26-2011, 12:54 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I would agree hpete . I have seen wire looms chafed under the vehicle on pickups also, causing shift problems. A little wire harness repair cured them.
Old 12-26-2011, 03:02 PM
Beerman28
thanks for the help. I'll let you know what i find out tomorrow. are there any specific codes i should look for that would indicate an electrical problem. or would they be self explanatory
Old 12-26-2011, 05:35 PM
pricesgarages's Avatar
does it neutral out after 2nd or just not go if it neutals out its internal 3-4 clutches if it just stays in 2nd it could be electrial theres a flat sensor on the bottom of the valve body called a map sensor it also detects what gear the trannys in if its bad it willnot aways throw a check engine light and can cause shifting issues if u have access to a scan tool look at current gear and see if it incresses with engine speed if it stops at 2nd its electriacal if it goes to 4th its mechanical
Old 12-26-2011, 05:59 PM
Beerman28
It revs up like it wants to shift into third, but it doesntt just stays in 2nd
Old 12-26-2011, 06:04 PM
its internal then
Old 12-27-2011, 06:00 AM
Beerman28
Hooked it up to the scan tool this mourn. No codes. it shows shifting into 3rd. when you manually shift into second it will run about 30 mph at 19-2000 rpm. if you try to shift up to third it revs up to about 3000 rpm at the same or less speed, but shows shifting up to 3rd?
Old 12-27-2011, 01:03 PM
sbchevfreak's Avatar
Licenced Automotive Technician
If it shows a commanded shift to 3rd, and the rpms flare up, then you have a friction element that is severely slipping. If the rpms are going up like that there should be a code for "incorrect gear ratio", or something similar, likely P0733. With the symptoms you describe, I would be looking into the C3 friction element, as it is specific to 3rd range.
4l60. ? Crusher1959 Transmission - Rearend 4 04-11-2011 05:13 PM
Need to swap out a 4L60 in 1988 GMC with a 1992 4L60 limp'n-gmc Transmission - Rearend 6 03-10-2011 04:17 PM
4l60 e k-star Transmission - Rearend 4 04-05-2008 02:28 PM
4L60 question AGRO32 Transmission - Rearend 4 12-21-2004 06:27 PM
thm 700 r4 4l60 lawyernie Introduce Yourself 2 12-07-2004 03:36 PM
