4L60-E problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 09:10 PM
4L60-E problem
ok i have a 98 s10 4wd i have mild 305 in it and i noticed today that if i manually down shift to second say at a red light and decide to go it seems to slip this is the only time it does it. i have never tinkered with auto trannies so any help you guys can give would be helpful so thanks in advance
Old 06-17-2010, 09:17 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
4l60e when placed manually in 2nd gear is IN 2nd gear. this was GM method to reduce power in low traction situations ( snow) or ice
Old 06-17-2010, 10:15 PM
but i have done this tons of times and it has never did this before it always wanted to go but now it just seems to slip
Old 06-18-2010, 06:10 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The band is burned if the trans is slipping
Torque converter problem??? blacklabzeke Transmission - Rearend 2 12-31-2008 03:55 PM
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
