4L60 E Torque Converter Locks and Unlocks in a continous cycle - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 09:29 PM
I've got a 1998 GMC with a 305 Vortec w/4L60 E the problem is it keeps locking and unlocking causing the flex plate to flex in and out more than it should. This causes the plate to break at the bolt holes and around the crankshaft. This is the 5th time it's done this. I'm putting in a new or should I say another 4L60 E transmission but I'd like to be able to fix the one I have. Any ideas as to what is causing this problem. I've changed the torque converter lock-up solenoid.
Old 09-19-2011, 08:41 AM
SSedan64's Avatar
Have a Trans shop run a scan on it. There are several external things that can cause the TCC to cycle, ECM, Brake Light switch, Ignition switch etc..
Worth a try before you dig into it.
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 04:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 06:47 AM
700-r4 / 4L60 converter lock up wire diagram Crosley Transmission - Rearend 0 09-13-2009 09:50 AM
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 11:05 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
