Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60 no reverse
Thread: 4l60 no reverse
Old 01-30-2011, 10:45 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by T-bucket23
A friend of mine has a GMC Sonoma, I cant remember if it is a 93 or a 98. I know it has the 4l60 transmission. All forward gears work fine, shifts nice and crisp etc. It will not backup. The fluid is full and looks and smells fine. Could this be something stupid or is it a rebuild. The truck is really in sad shape and is just used as a lot truck for plowing snow. It not easy to plow with no reverse lol.
Thanks for any insight.
if you have verified the trans a good 2nd gear and 4th gear... then the drive shell must be functioning
then a problem in the low - reverse clutch pack or the reverse input clutch. Those 2 clutch packs create reverse
