-   -   4l60 no reverse (http://www.hotrodders.com/forum/4l60-no-reverse-191680.html)
T-bucket23 01-30-2011 08:29 AM
4l60 no reverse
A friend of mine has a GMC Sonoma, I cant remember if it is a 93 or a 98. I know it has the 4l60 transmission. All forward gears work fine, shifts nice and crisp etc. It will not backup. The fluid is full and looks and smells fine. Could this be something stupid or is it a rebuild. The truck is really in sad shape and is just used as a lot truck for plowing snow. It not easy to plow with no reverse lol.
Thanks for any insight.
Crosley 01-30-2011 10:45 AM
if you have verified the trans a good 2nd gear and 4th gear... then the drive shell must be functioning
then a problem in the low - reverse clutch pack or the reverse input clutch. Those 2 clutch packs create reverse
:D
T-bucket23 01-30-2011 02:38 PM
Thanks Crosley. I told him there generally is no easy fix, but I promised I would ask.
