4l60 no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2011, 09:29 AM
T-bucket23's Avatar
Wiki Edits: 26
4l60 no reverse
A friend of mine has a GMC Sonoma, I cant remember if it is a 93 or a 98. I know it has the 4l60 transmission. All forward gears work fine, shifts nice and crisp etc. It will not backup. The fluid is full and looks and smells fine. Could this be something stupid or is it a rebuild. The truck is really in sad shape and is just used as a lot truck for plowing snow. It not easy to plow with no reverse lol.
Thanks for any insight.
Chet
Old 01-30-2011, 11:45 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
if you have verified the trans a good 2nd gear and 4th gear... then the drive shell must be functioning
then a problem in the low - reverse clutch pack or the reverse input clutch. Those 2 clutch packs create reverse
Old 01-30-2011, 03:38 PM
T-bucket23's Avatar
Wiki Edits: 26
Thanks Crosley. I told him there generally is no easy fix, but I promised I would ask.
Chet
4l60 e k-star Transmission - Rearend 4 04-05-2008 03:28 PM
4l60 Reverse Only SHOOTISTLB Transmission - Rearend 4 08-04-2007 02:50 PM
What is applied when a 4L60 is in reverse Billvill Transmission - Rearend 21 08-04-2007 10:11 AM
thm 700 r4 4l60 lawyernie Introduce Yourself 2 12-07-2004 04:36 PM
4l60-e no reverse problem ragman1 Transmission - Rearend 6 10-18-2004 05:06 PM
