4L60 : no reverse - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2012, 01:32 PM
4L60 : no reverse
After reading this conversation I found out what went wrong with my own car and his transmission. I've missplaced two bolts it deffenetly makes a diffrance!! So THANKS A LOT !! It spares me a lot of work
Old 12-30-2012, 02:45 PM
Crosley's Avatar
Wiki Edits: 1659
Welcome to Hotrodders.
Glad to see you have repaired the trans with help from information here.
4l60 reverse abuse function RupertJ Transmission - Rearend 1 03-15-2011 07:38 PM
4l60 no reverse T-bucket23 Transmission - Rearend 2 01-30-2011 02:38 PM
4l60 Reverse Only SHOOTISTLB Transmission - Rearend 4 08-04-2007 01:50 PM
What is applied when a 4L60 is in reverse Billvill Transmission - Rearend 21 08-04-2007 09:11 AM
4l60-e no reverse problem ragman1 Transmission - Rearend 6 10-18-2004 04:06 PM
