4l60 no reverse/forward on neutral - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 07:27 PM
hey guys so here is my intro i am a new father as of march 8th 2011 to a babygirl and am very happy to bring her home in my trailblazer 4l60e. but apperantly i was a lil to happy a few days ago. one morning at the shop where i work i did a tranns flush and new filter and pan gasket.
i refilled the tranns. after servicing it and filled it with 4.5 quarts reason being alldata required 5. i ran it through the gears and checked the fluid level and and added more fluid point is i serviced it and then drove it around. i litereally went through every gear and everything worked fine even reverse but when i went home i backed up from my parking spot threw it in drive and burned out for a good 30 feet...oops...thats when reverse did not work any longer and now when i put it in neutral it goes forward...any help??? :/
Old 03-11-2011, 10:13 PM
Rebuild the trans. ???
No reverse and forward everywhere.... go figure
Old 03-12-2011, 11:33 AM
T-bucket23's Avatar
Wiki Edits: 26
Start with the simple stuff. Going forward in N may indicate the linkage is messed up.
Chet
wants to go in reverse when in neutral mainejohn Transmission - Rearend 6 02-27-2011 06:15 PM
th350 forward to reverse sooper Transmission - Rearend 4 05-15-2010 12:03 PM
700r4 Lurches forward when in neutral Jake_Dragon Transmission - Rearend 2 01-11-2010 03:01 AM
1989 4l60( 700r4) shifts from 2nd to neutral Riby Transmission - Rearend 10 04-07-2006 01:51 AM
TH 350 no forward no reverse joesnova2 Transmission - Rearend 4 05-14-2004 11:48 PM
