4l60 Pump cover 3-4 Exhaust question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2007, 03:12 PM
blacklabzeke's Avatar
I picked up another pump for my rebuild and noticed there was another port in pump cover. From the information I could find this is a 3-4 exhaust port. The new pump has it but the old pump does not (shown in the attached pictures). Both covers are casting 570 and the bodies are 732. Should this hole be plugged since the old pump did not have it? What is its function other than the obvious.
ID:	26034   Click image for larger version
Old 12-07-2007, 05:58 PM
Did some digging on the site and found the information I needed from a post in 2004. The link below pretty much cover it.
Thanks again Crosley
700R's limitations
Oil pump question 92 sbc Eric64 Engine 3 06-07-2007 06:14 PM
High Volume/Pressure Oil Pump Question... 71gtx Engine 1 05-14-2007 08:18 PM
Exhaust question for super/turbo members jameskirk1 Engine 7 08-18-2005 07:58 PM
Question about a BG 400 fuel pump...? Bumpstick Engine 5 03-17-2004 01:03 PM
700r4 Front Pump Question ChevyCam Transmission - Rearend 13 03-15-2003 08:23 PM
