4l60 reverse abuse function - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2011, 05:58 PM
Can someone explain the function of this valve? I have a 99 Burban, 4L60, with no reverse. Studying the atsg manual only reveals that there is a valve and booster for reverse and no explanation of their function. There is not a sound when I select reverse. I have been reading the advice here in Hotrodder and it seems like you folks KNOW what you are talking about. I would like to try all the "easy" stuff first befor I tear it apart. Thanks
Old 03-15-2011, 07:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
mileage and age on the 1999 4L60E trans? Original trans to the burban?
Does the trans have 2nd gear, and 4th gear?
Not sure what valve you speak of.... the main boost valve is a multi stage unit that boosts reverse pressure
4l60 no reverse T-bucket23 Transmission - Rearend 2 01-30-2011 02:38 PM
Wiring function differences between 700R4//4L60/4L60E? corvettetonybone Transmission - Rearend 8 03-16-2009 08:03 PM
4l60 Reverse Only SHOOTISTLB Transmission - Rearend 4 08-04-2007 01:50 PM
What is applied when a 4L60 is in reverse Billvill Transmission - Rearend 21 08-04-2007 09:11 AM
4l60-e no reverse problem ragman1 Transmission - Rearend 6 10-18-2004 04:06 PM
