4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2007, 07:25 PM
4l60e
I have installed a 5.3 vortec with a 4L60E tranny in a 68 chev p/u with a B & M Mega Shifter. Painless harness everything appears to be hooked up. The trans. and torque converter were dry we filled with oil but nothing happens when we put it in any gear. now what?
Old 02-18-2007, 07:48 PM
Sounds like converter to pump engagement problem. The converter should only move 1/8" toward the flywheel when installing the trans. If the converter is pulled too far forward it will disengage the pump lugs = no line pressure and no movement. Otherwise I would suspect pump gear breakage. The easiest way to check is with a pressure gauge installed in the port above the gear selector shaft. No line pressure means no pump movement. If you have pressure, something broke (doubtful)...
Old 02-18-2007, 07:57 PM
I'll check that i do have a pressure gauge for that. Thanks, mrd
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 01:51 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
4L60E questions??? Decotoxiver Transmission - Rearend 6 02-26-2006 08:27 AM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
94 S-10 LT1 with 4L60E conversion The Crazy Coz Hotrodders' Lounge 2 12-03-2002 09:39 PM
