-   -   4l60e (http://www.hotrodders.com/forum/4l60e-147871.html)
butters 11-08-2008 08:20 AM
4l60e
myself and a friend of mine who has tranny exsperience just rebuilt my 4l60e 2 weeks ago it ran fine shifted good exept for the fact i didnt have od we figured my od cylinode was bad till the other day when i was pullin out of a drive way my truck jerked and made a weird noise almost like a standard does when ya slip the clutch it still shifts fine i was just wounderin what that may be and would it have anything to do with my overdrive problem. this truck is a 93 gmc 2 wheel 5.0
butters 11-08-2008 08:22 AM
crap forgot would i be better off to switch out trannys maybe i heard 4l60e's are know to brake was thinkingbout going back to the 700 r4 or sumthing along thos lines
Crosley 11-08-2008 09:14 AM
Mileage on this trans if known?
Any recent repair work?
You can not place a 700r4 non electronic trans into this truck easy... the ECM looks for feedback from the 4L60E trans. No feedback = trouble codes set.
I doubt you have a shift solenoid problem since there are only two shift solenoids in this trans that perform double duty for shifting 1 - 2 - 3 - 4.
I would suspect a worn out 2-4 band with a high mileage trans
butters 11-08-2008 11:36 AM
we just rebuilt it the trans has 173k
Crosley 11-09-2008 12:40 PM
You could check the band clearance, check the pressures during operation.
The noise could have been many things with the transmission or not.
Were the electronic solenoids replaced during the rebuild?
