4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2008, 07:20 AM
4l60e
myself and a friend of mine who has tranny exsperience just rebuilt my 4l60e 2 weeks ago it ran fine shifted good exept for the fact i didnt have od we figured my od cylinode was bad till the other day when i was pullin out of a drive way my truck jerked and made a weird noise almost like a standard does when ya slip the clutch it still shifts fine i was just wounderin what that may be and would it have anything to do with my overdrive problem. this truck is a 93 gmc 2 wheel 5.0
Old 11-08-2008, 07:22 AM
crap forgot would i be better off to switch out trannys maybe i heard 4l60e's are know to brake was thinkingbout going back to the 700 r4 or sumthing along thos lines
Old 11-08-2008, 08:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Mileage on this trans if known?
Any recent repair work?
You can not place a 700r4 non electronic trans into this truck easy... the ECM looks for feedback from the 4L60E trans. No feedback = trouble codes set.
I doubt you have a shift solenoid problem since there are only two shift solenoids in this trans that perform double duty for shifting 1 - 2 - 3 - 4.
I would suspect a worn out 2-4 band with a high mileage trans
Old 11-08-2008, 10:36 AM
we just rebuilt it the trans has 173k
Old 11-09-2008, 11:40 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You could check the band clearance, check the pressures during operation.
The noise could have been many things with the transmission or not.
Were the electronic solenoids replaced during the rebuild?
700R for 4L60E swap? flynbrian48 Transmission - Rearend 6 01-29-2009 10:56 PM
98 astro 4l60e what swaps out? 3rdgenLT1 Transmission - Rearend 4 06-06-2007 09:16 AM
4L60E rebuild kit ????'s Turbonoma Transmission - Rearend 0 04-14-2007 12:10 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
