Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e
Thread: 4l60e
Old 12-26-2012, 11:34 AM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by rickq View Post
I just took it for a ride and in third gear I have 70 lbs. of pressure,2nd gear also has 70 lbs.
70 psi is not far above minimum. Pressure should rise and fall with throttle. Should be higher in reverse gear.
If 3rd is not holding, there likely is a problem with 3 - 4 clutch pack
