Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e
Thread: 4l60e
Old 12-26-2012, 12:49 PM
dwwl dwwl is online now
Did you rebuild the pump when you did tranny? What did you do to the tranny for a rebuild. Did you install the new seals? Any boost in preasure? The preasure seem low to me. I'm use to the 200 4r and preasurs in the 175- 225 range or higher. Usualy if the preasure is not good ore there is a leak the 3-4 clutches will with very few miles on them.
