Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e
Thread: 4l60e
Old 12-27-2012, 06:20 PM
dwwl dwwl is offline
Were do you start? Your take the tranny back out and take it apart. I'm thinking that the 3-4 clutch pack it ruined. If so, that means that you didn't have enough preasure. IF those clutchs are bad, then i'd guess the rest of the clutchs are going to have to be looked at. Double check everthing, then check it again when you assemble. When i rebuilt my 200 4r I lined everthing up in order and rebuilt each section indilvidualy as i put it back together. Use a presure gauge when done. If this was your first rebuild, i'd suggest a vidio of that tranny. There alot of little things you have to do and remember to do or your going to have problems. I"m sure you were close, just remember to use the gauge because it'll tell you your problems. Don't feel bad, It took me a month to complete mine. Mline turned out good and I enjoyed it so much, I built another one forthe fun of it.
