Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4l60e
Thread: 4l60e
Old 12-27-2012, 11:56 PM
rickq rickq is offline
4l60e
When I hooked up the scanner and checked the pressure at the different settings (1-10)it started at 60lbs and went as high as 175 at setting 6 then dropped to 60lbs for the rest of the test. I think you are right though, I will most likely pull it back out.thanks ps. I have the cd for rebuilding it.
