4l60e
hello i just put in a transmission i took from a 97 tahoe and put it in 96 suburban .the problem im have is that it will go in reverse find but when putting it in drive you have to idle the engine hi then it goes but then when come to a stop you have to do it again its a 4l60e transmission
low on fluid,
bad trans If reverse works fine , then there should be enough pressure to operate forward gears. Plus there may be a solenoid difference in the 3-2 circuit. Different ohm rating
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 4L60E Bellhousing Change | slydelon | Transmission - Rearend | 2 | 06-01-2010 01:18 AM |
| 4l60e - No reverse after rebuild - Low line pressure? | reddeth | Transmission - Rearend | 5 | 06-03-2009 09:12 AM |
| 700r4 to 4L60E swap | chevy_c10 | Transmission - Rearend | 19 | 05-10-2009 08:30 AM |
| 98 astro 4l60e what swaps out? | 3rdgenLT1 | Transmission - Rearend | 4 | 06-06-2007 09:16 AM |
| questions about 4l60e | 85ta383 | Transmission - Rearend | 3 | 04-10-2005 08:27 AM |
