Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E - 2 Questions With Pics
Old 04-21-2009, 08:28 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
be careful mistakes are expensive as you replace parts..
first photo is PWM valve assembly , that is a normal valve setup. I'd use a TransGo replacement. A heavy wear area
2nd foto shows a Sonnax replacement - repair valve for the PWM system
3rd - 4th fotos is the lock up valve assembly, nothing out of alignment there... although one foto is completely useless - blurred
