4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2012, 09:58 AM
4l60e
my 4l60e will not down shift manually to 1st gear but drives fine
Old 01-10-2012, 10:07 AM
Last journal entry: update
So what, exactly, are you posting for? Are you asking how to get manual first?
When I first got my '95 Z28 convertible ( with the 2.73:1 axle, not the 3.23:1 option ) I had to use a hammer and sharpened straight screwdriver to knock a plastic tab off the shifter ( carefully removed the center console first ) to get manual first. That's all it took. And I only did that for winter driving, because with the Hypertech tuner it would hold first to 6200 at full throttle. I liked that.
If you're talking about a pickup, it may well be an electronic thing so that you can't have first above a certain speed. If this is your problem, then you'll need to find a tuner or send your computer out. I used www.gmtuners.com to recalibrate the speedometer and shift points of my '06 Sierra when I changed the axle ratio. They had the best price and the best service. It cost me much less than buying another Hypertech.
4l60e andermke Transmission - Rearend 1 05-25-2010 06:33 AM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e Einarg Transmission - Rearend 1 12-04-2008 02:13 AM
4l60e butters Transmission - Rearend 4 11-09-2008 11:40 AM
does anybody now anything about a 4L60E? 94impalass Transmission - Rearend 14 07-16-2006 09:24 AM
