-   -   4l60e (http://www.hotrodders.com/forum/4l60e-224241.html)
C THomas 09-21-2012 05:48 PM
4l60e
Like to use a valve body from a 1994 4l60 e and install it in a 1997 If I change out all the solenoids will it work correctly with lockup .
mmerlinn 09-22-2012 10:30 PM
No.
The 94 is a non-PWM valve body and will not fit 95 and later which are all PWM.
pricesgarages 09-23-2012 02:42 PM
u have to use a 97 up with the matching seperator plate or a trans go univesal plate
