4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 04:48 PM
4l60e
Like to use a valve body from a 1994 4l60 e and install it in a 1997 If I change out all the solenoids will it work correctly with lockup .
Old 09-22-2012, 09:30 PM
Wiki Edits: 85
No.
The 94 is a non-PWM valve body and will not fit 95 and later which are all PWM.
Old 09-23-2012, 01:42 PM
pricesgarages's Avatar
u have to use a 97 up with the matching seperator plate or a trans go univesal plate
4l60e bordeaux Transmission - Rearend 2 04-22-2010 05:58 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e no OD or D jbroome2 Transmission - Rearend 4 03-07-2010 10:35 AM
4l60e Einarg Transmission - Rearend 1 12-04-2008 02:13 AM
What is the '60' in 4L60E 36scsc Transmission - Rearend 1 10-26-2004 12:41 PM
