4l60e - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-28-2012, 02:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Odd the PSI reading drops off after hitting 175 then drops to 60.
Since you installed a 13 vane kit in the pump, what did you set the clearance at for the pump rotor? Usually .0015 is a good place to be at, no more than .002.
The pump cover ( often called 'stator support ) should be completely flat and smooth.
Still possible you have a faulty PCS , but you mention the solenoids were replaced. I take that to mean All electronics were replaced?
  #17 (permalink)
Old 12-29-2012, 07:21 PM
4l60e
I am going to tack it back out thanks.
  #18 (permalink)
Old 01-07-2013, 06:27 PM
4l60e
I replaced all but that one !! (epc)oops
4l60E Bcowboy1 Transmission - Rearend 1 03-06-2012 08:02 PM
4l60e 45silas Transmission - Rearend 1 09-27-2010 08:03 PM
4l60e andermke Transmission - Rearend 1 05-25-2010 06:33 AM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e Einarg Transmission - Rearend 1 12-04-2008 02:13 AM
