4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 09:54 AM
4l60e
I rebuilt this tranny about 100 miles ago and now when it goes into 3rd gear it does not hold, put scanner on and hooked up pressure gauge to it and it seems ok.
Old 12-23-2012, 05:59 AM
SSedan64's Avatar
3rd gear is slipping?
What were you pressure readings?
Could be too much 3-4 clutch clearance, cut Piston Seal etc..
Old 12-26-2012, 10:29 AM
trans
I just took it for a ride and in third gear I have 70 lbs. of pressure,2nd gear also has 70 lbs.
Old 12-26-2012, 10:34 AM
Crosley's Avatar
Wiki Edits: 1659
70 psi is not far above minimum. Pressure should rise and fall with throttle. Should be higher in reverse gear.
If 3rd is not holding, there likely is a problem with 3 - 4 clutch pack
Old 12-26-2012, 10:37 AM
4l60e
the pressure does not change with the throttle, reverse has about 90psi.
Old 12-26-2012, 12:49 PM
Did you rebuild the pump when you did tranny? What did you do to the tranny for a rebuild. Did you install the new seals? Any boost in preasure? The preasure seem low to me. I'm use to the 200 4r and preasurs in the 175- 225 range or higher. Usualy if the preasure is not good ore there is a leak the 3-4 clutches will with very few miles on them.
Old 12-26-2012, 02:05 PM
4l60e
Yes I rebuilt the pump and put a 13 vane pump instead of the 10 vane,all new seals, new steels and clutches,new reverse drum,corvette servo,input shaft and drum, new solenoids, just about everything is new(could have bought a rebuilt cheaper)but what the hell,it was my first one!! the first hundred miles where great!!
Old 12-26-2012, 03:41 PM
Sounds like your going to get more experience. Did you put a pressure gauge on it at first, and is it the same as now. I still think those pressures are to low. I rebuilt a 200 4r and my pressures are above 175 up to 225. Its possible that you may of left to much clearance in the clutch pack, or bad seal.
You should of gotten some pressure rise when the rpm's rose. That is why you could have a pump problem also
Old 12-26-2012, 03:50 PM
Crosley's Avatar
Wiki Edits: 1659
You replaced plenty of parts. But you missed something.
The pressure should increase with throttle.
The PCS may be faulty. The AFL valve may be worn out.
Boost valve not fully installed in the pump
time to check a few items inside the pan
Old 12-26-2012, 04:00 PM
Not knowing the 4l60E i checked one of the web sights. Your pressure is way to low. I agree with rickq you need to rebuild or atleast look to see what is bad and always double check everthing before the next step. good luck
Old 12-27-2012, 11:09 AM
4l60e
ok where do I start?
Old 12-27-2012, 06:20 PM
Were do you start? Your take the tranny back out and take it apart. I'm thinking that the 3-4 clutch pack it ruined. If so, that means that you didn't have enough preasure. IF those clutchs are bad, then i'd guess the rest of the clutchs are going to have to be looked at. Double check everthing, then check it again when you assemble. When i rebuilt my 200 4r I lined everthing up in order and rebuilt each section indilvidualy as i put it back together. Use a presure gauge when done. If this was your first rebuild, i'd suggest a vidio of that tranny. There alot of little things you have to do and remember to do or your going to have problems. I"m sure you were close, just remember to use the gauge because it'll tell you your problems. Don't feel bad, It took me a month to complete mine. Mline turned out good and I enjoyed it so much, I built another one forthe fun of it.
Old 12-27-2012, 10:56 PM
4l60e
When I hooked up the scanner and checked the pressure at the different settings (1-10)it started at 60lbs and went as high as 175 at setting 6 then dropped to 60lbs for the rest of the test. I think you are right though, I will most likely pull it back out.thanks ps. I have the cd for rebuilding it.
Old 12-28-2012, 10:28 AM
when you get ready to rebuild it, take it apart first and see what is bad. I studied the tranny, 200 4r, for some period of time, as well as the net, and built mine with red clutches. Low reverse with standard 6 count, forword with 5 count instead of the stock four. Direct with 8 enstead of six, overrun with 3 enstead of two, and overdrive with 3 enstead of two. Us the wide band and bigger valves and I was ready to go. I think you can do some of that with the 700 also. I wasn't in any hurry becasue mine had a running 350 in it. I just wanted the overdrive.
buy the better clutches and it will last longer.
Old 12-28-2012, 11:59 AM
something i should of told you. Check the net for everthing of interest to you, and print it off. I added it to my collection and it turned out to be good reference material.
also air check your clutch packs as you put it back together and again after you complete it. Patience is a virtue and keeping the assemble clean is also a big plus.
The Following User Says Thank You to dwwl For This Useful Post:
rickq (12-28-2012)
4l60E Bcowboy1 Transmission - Rearend 1 03-06-2012 08:02 PM
4l60e 45silas Transmission - Rearend 1 09-27-2010 08:03 PM
4l60e andermke Transmission - Rearend 1 05-25-2010 06:33 AM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 06:22 PM
4l60e Einarg Transmission - Rearend 1 12-04-2008 02:13 AM
