Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E 3-4 clutch pack clearance question
Old 01-07-2013, 01:55 PM
rick 427's Avatar
rick 427 rick 427 is offline
Last journal entry: The 32's
The ATSG is giving the set up for the 4L60 ,not the E... On the E trans,the 2 part thin retainer plate[with legs down] and the stepped plate used on the 4L60 was replaced with the 1 piece thick plate [with the legs down],then clutch,steel,clutch,etc..... Put your new set-up together with WET clutches,air check it a few times to seat everything,and check the clearance. If you're in the .030-.060 range,you're good.
