Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E 3-4 clutch pack clearance(red eagle & kolene steels)
Old 08-10-2012, 06:35 AM
dogwater dogwater is offline
Last journal entry: Still running strong
I had the same problem,the strange thing was I quit working on it for a day or two and it went together just fine.You might try air checking it a few times to squeeze some of the atf out of the clutches,but dont air check the 3-4 piston cause youll blow out the seals without the snap ring on.I was told that it does not make a differance if the clutches were freashly soaked with atf but I think it does.
The Following User Says Thank You to dogwater For This Useful Post:
abbazabba (08-10-2012)
