4l60e 3rd gear starts
hello everyone i just rebuilt the 4l60e in my 95 tahoe. now i am getting only 3rd gear starts. if i manually shift it into 1st or 2nd it will start in those gears. it has 1st 2nd and 3rd gear only if manually shifted. no od or tcc apply. i have read that these trucks have ignition switch problems. could this be it or is it something electronic in the trans? thanks for any help
the rear planetary was broke and the 3-4 clutch pack was fried
There is a exhaust hole behind the 2 shift solenoids that needs to be enlarged or you get 3rd gear starts Ill dig out this tsb and post it for you the bigger hole is to let more oil exhaust when solenoid is off I see it in pretty much every second 4l60e that I build before that though there is an ignition problem to check with truck running check for power at the trans fuse in your dash if theres no power on either side you need a new ignition switch hope this helps and Ill dig up that tsb for you.
ok so i bought a code reader today and got the following codes:
59,66,67,81,82,83 any help would be much appreciated thank you |
Quite a few codes, I would bet that you've got some wires pinched or not hooked up properly.
with the amount of codes you have, its either that or the main harness going to the trans is not hooked up or plugged in solidly. |
| Powermaster starter gear walks into flexplate after engine starts | zildjian4life218 | Engine | 4 | 05-31-2011 08:51 AM |
| 4l60e starts in third, sometimes | mbennett | Transmission - Rearend | 9 | 04-13-2010 10:35 PM |
| 4L60E 4th gear | sleeper71chevelle | Transmission - Rearend | 1 | 08-17-2009 04:18 PM |
| 4L60E no first gear | runheavy | Transmission - Rearend | 4 | 01-15-2008 07:03 AM |
| New TH350 Starts out in 3rd gear? | roygrimm | Transmission - Rearend | 2 | 01-22-2002 07:37 PM |
