4l60e 4wd to 2wd - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2006, 09:53 PM
4l60e 4wd to 2wd
Ok guys I have a 4l60e out of a 94 s10 blazer that i want to use along with the freshly rebuilt 4.3 vortech i have. The problem is its currently hooked to a transfer case I was wondering how hard it is to change the tail shaft so i can install it in my 46 chevy pickup. Or would it just be easier to get a different tranny (one thats already 2wd) the tranny shops all want around $400 any help would sure be appriciated has anyone done this (I know theres a few of you that have)
Thanks
Old 11-10-2006, 09:31 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
This has been discussed in here a few times before, You are better off going with a transmission that is already a 2WD than trying to convert a 4X4 to 2.
The exact same advice goes for those wishing to swap from 2 to 4WD, get the transmission already set up for that purpose.
Old 11-10-2006, 08:11 PM
airworld2's Avatar
4l60e
to change out put shaft is easy and normal charge at my shop is about 150 bucks. 4x4 shaft would cost extra 50 buck's but since you would need a 2 wheel shaft most shop have a few extra laying around, but if not would be 25 bucks extra.
it should take about an hour or less to change the shaft either way for someone that is doing this every day. now keep in mind the condition of the transmission would remain the same good , bad ,or other wise. unless you do go the extra step to replace clutch plates and band seals rubbers that do go into a full rebuild.........
airworld2
4wd to 2wd conversion burninrubbah617 Transmission - Rearend 4 01-20-2006 03:06 PM
700R 2wd or 4wd whats the difference?? Mighty Mouse S-10 Transmission - Rearend 5 06-08-2005 08:48 PM
4wd to a 2wd.. frame info 53fordguy General Rodding Tech 9 12-14-2004 05:03 AM
4l60, Or 4l60e 1994 Gmc 4wd buddy powell Transmission - Rearend 4 10-14-2004 06:16 AM
2WD TH350 to 4WD TH350 rambo_z28 Transmission - Rearend 6 07-17-2003 05:17 PM
