4l60E 4X4 2WD DIFFERENCES - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2010, 06:00 AM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
I was wondering if I could just change the ouput shaft on a 2wd 4l60e and install the 4x4 output shaft into it.
Its a 3 piece case model. Is the 700r4 4x4 output shaft the same as the 4l60e output shaft?
Thanks,
Pugsy
Old 01-06-2010, 09:47 AM
Wiki Edits: 85
Thanks,
Pugsy
1. Change shaft and go.
2. 700-R4 shaft not the same but will work fine.
Old 01-06-2010, 09:51 AM
poncho62's Avatar
Wiki Edits: 5
I believe you can, but I think the output shaft goes in the case first, meaning that you have to gut the tranny.......Turbo 350 is that way anyways.....
BTW...Happy Birthday.....belated.....
Ontario Rodders
Old 01-06-2010, 10:36 AM
123pugsy's Avatar
Wiki Edits: 29
Shaft is changed. I ripped down both units and swapped them out.
The 700r4 shaft did indeed have more lube holes.
The governor gear on the shaft wouldn't matter I suppose.
Poncho: the 4l60e and 700r4 have a snap ring holding in the shaft, but its almost a full teardown anyways.
Old 01-06-2010, 10:37 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
All the tranny's I have had required the trans to be gutted all the way to replace the tailshaft..Saying that the only difference between 2wd and 4 wd trans was the tailshaft and tailshaft housing..but then knowin Murphy's Law as well as I do there is a trans made somewhere somehow that will make me out to be a liar...
Sam
4l60e 4x4 problem. Loud Clicking!! 327amc Transmission - Rearend 28 02-23-2012 10:09 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
4l60e 4wd to 2wd pickjays Transmission - Rearend 2 11-10-2006 08:11 PM
2wd to 4x4 700r4 QUINTANA64 Transmission - Rearend 7 04-05-2006 05:20 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
