4l60e 4x4 To A 4l80 ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2007, 06:23 AM
I bought a 1996 chevy Tahoe at an auction, found there to be a b&m shift kit also no reverse, shifts very hard and winding out more than a shift kit would normally, the tranny oil was severely burnt. My question is would it be possible to put a tranny that was only a 2wd, is there a converter to make 4wd? also is it possible to put a 4L80 into my chevy and what years would be interchangeable Thank You Roxi
Old 11-01-2007, 07:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
4L80E is not a direct swap from a 4L60E trans.
From your description... the current trans has a broken sun shell. No reverse , long time to shift ; indicates the trans is skipping 2nd gear and hitting 3rd gear. A broken sun shell produces NO reverse and NO 2nd gear and NO 4th gear.
A 2WD trans needs the output shaft changed to a 4x4 output shaft to bolt in place of a 4x4 trans...
t-400 in place of a 4L60E in a 4x4 ? the frog Transmission - Rearend 2 08-22-2007 07:15 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
87' Bronco 2 4x4 One touch 4x4 button IAMCANADIAN Electrical 1 02-08-2003 03:49 PM
