4L60E or 700r ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2010, 06:51 PM
4L60E or 700r ?
Looking for the better automatic that is build-able to around550 hp/flbtorque probably a little less.
this is nice:The 4L60E beefed up
or The tried and time tested warhorse:Warhorse
Now I am an oldies lover thus the 383 1970 Nova i am building. So the 700r that has passed the trials plus appeals to me.
But i am also a firm believer in technological progress and think(help me out here) that a transmission that has evolved almost 3 decades SHOULD be superior.
The tranny will use a 1800 custom Torque converter to spin it from the 383 CID.
I am looking for extreme fast launches over top end, but just barely street-able.
So i am just asking which tranny is the better and why. i will up date the build periodically and mention the part and who ever talked me into it
Old 09-12-2010, 08:00 PM
Overdriv's Avatar
Well as you probably know they are the same transmission except the 4L60E is the electric control shift. They make a stand alone controller for the "E" but it is a bit pricy. Depends on what you want I guess, but I'd save the money and go the 700R4.
I keep hoping someone will come out with a controller that will allow automatic shifting and full manual electric shifting for the 4L60E, for under $200. I think it would be cool to rig up a push button shift in a hot rod.
Old 09-12-2010, 08:16 PM
Check your spark plug gaps
i would go with the 700r4 to keep things simple and less expensive. I have an 89 K1500 with the 700r4 and I also have a 93 K1500 with the 4l60e. I like the electronic shift a lot better than the throttle valve but if you get a good 700 with the throttle valve cable properly adjusted you should be happy with it. When you say the vehicle will be barely street able what do you mean? Are you saying that you want to drive it as a daily driver or you just want to drive it to the track and cruise with it a bit? Just curious of why you want an overdrive trans?
Old 09-12-2010, 08:35 PM
Barely streetable to me means a lobing-high octane-comp:9.6-1 ish-DOTslicks-etc etc that will still pass the sniffer at inspection time.
As to why those tranns.-availability-reliability-budget. BUT i am open to better suggestions always. The day i dont learn something will probably be the day i die.
Old 09-12-2010, 08:45 PM
Ah well it's obvious i am no tranny man.
So the Gears/planet/bands are all the same in these 2 ?
No new tech in the 4L60?
If that is the case no sense in worrying there.
But is the 700r that I linked a good tranns and reasonable price?
Old 09-13-2010, 06:18 PM
I think the link is a little pricey, try this one out http://racetransmissions.com/store/i...th/1_25_56_112 these guys get used a lot on the tv show extreme 4x4 and the other tv shows on powerblock. I am not going to recommend these guys nor say they are bad but I have a transmission in my truck from MadDogTransmissions http://www.maddogtransmissions.com/v...es/default.htm I have had it in my truck for a little over 1 year now. I love it, it provides firm positive shifts
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 09:12 AM
700R for 4L60E swap? flynbrian48 Transmission - Rearend 6 01-29-2009 10:56 PM
4L60 convert to 700R figair Transmission - Rearend 7 07-28-2008 03:50 PM
questions about 4l60e 85ta383 Transmission - Rearend 3 04-10-2005 08:27 AM
Chevelle Coversion to 700r using 86 camaro trans 700r theroq Transmission - Rearend 0 02-08-2004 12:03 PM
