-   -   4l60e to a 700r (http://www.hotrodders.com/forum/4l60e-700r-208883.html)
malcolmz28 11-17-2011 02:19 AM
4l60e to a 700r
I have a 94 lt1 camaro with a 4l60e tranny I want a manuel vaulve body put in it but no one makes them but they make them for the 700r tranny can I put the 700r in the car if so what changes do I have to make
SSedan64 11-17-2011 12:35 PM
TransGo has a "4L60E-3" Reprogramming Kit that provides full Manual control.
http://transgoonline.com/products.ph...dcountview=Yes
Rossler has a Plug & Play controller "Little Black Box" for Full Man control.
http://www.rosslertrans.com/
The Ross-Lock may not be compatible with your Engine's ECM tho'.
malcolmz28 11-17-2011 02:21 PM
Will this allow me to shift manualy 1st to 4th in my auto trans I tried to call them but no answer it looks like a good kit I'm trying to set the car up as a drag car
SSedan64 11-17-2011 02:34 PM
It looks like the (-3) Kit is for Manual only, no electronic control.
The (HD2) Kit may work better for your setup, it gives full manual control but, works with OEM electronics, ECM.
HD@ >> http://transgoonline.com/products.ph...dcountview=Yes
Other >> http://transgoonline.com/products.ph...7&parent_id=97
SSedan64 11-17-2011 02:41 PM
The 93-LT1 T/A, Z-28 came with the 700R4 Trans. Not sure but, you may be able to use the 93 ECM and swap in a 700R4.
What about a programmer for the 4L60E Trans? These allow you to set Shift speed, boost Line Pressure etc..
I should have asked if you're going to use a Carb or keep the EFI etc..
