4l60e to 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2008, 06:58 PM
4l60e to 700r4
whats up guys hopefully some one can help i have a 1993 chevy 1500 it has a bad 4l60e i want to replace it with a 700r4 that i have is this possible even though the 4l60e is an electronic tranny
Old 05-10-2008, 07:26 PM
1993 4l60e trans question
my 1993 chevy 1500 has a 4l60e can it be replaced with a 4l60e from a different year or even a different car or does it need to be specifically for a1993 chevy 1500 thanks for the help
Old 05-10-2008, 07:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by static40
my 1993 chevy 1500 has a 4l60e can it be replaced with a 4l60e from a different year or even a different car or does it need to be specifically for a 1993 chevy 1500 thanks for the help
you need a 1993 or 1994 trans to bolt in for the electronics.
in 1995 GM changed the converter lock up strategy to PWM ... there is an additional solenoid and wire and different programing
Old 05-10-2008, 07:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the computer looks for feed back from the 4L60E trans.... this will set trouble codes & the check engine light turns 'on"
Old 05-11-2008, 08:39 PM
4l60e???
thanks for the info helped me alot. i found a 4l60e trans in a buik roadmaster 1994. i think that it would work. if i was to go the easy way out and try a th 350 would the computer make the truck run weird or would i just get a check engine light and the truck would run normal thanks for the help and quick responses guys
Old 05-11-2008, 08:48 PM
4l60e swap
thanks 4 the help will the check engine light be my only trouble. will the engine fuction normal even though the 4l60e is not noticed by the computer. thanks 4 the help
Old 05-11-2008, 09:37 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
It puts the system into a limp mode. It is not advisable to drive the vehicle continuously in limp mode.
93 4l60e to 89 700r4 questions Bumper Thumper Transmission - Rearend 4 06-06-2007 02:07 PM
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 09:16 PM
4L60E and 700R4 similarities martinr Transmission - Rearend 7 12-18-2005 05:07 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 04:34 AM
700r4 and 4l60e silm man Transmission - Rearend 9 09-02-2005 08:47 PM
