4l60e to 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2009, 02:22 AM
4l60e to 700r4
i have a 91 s15 jimmy 4x4 automatic with a 700r4 that is shot, so i wanted to swap it with a 4l60e that i had laying around from a 95 chevy 1500 4x4. any suggestions on the easiest way to make the swap on a limited budget?
Old 09-21-2009, 06:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Can not be swapped cheaply.
The 4l60e needs a computer type of controller to operate. Those run 600.00 dollars and higher
Old 09-21-2009, 09:13 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Agreed. Cheaper to rebuild the 700 and then you have a basically new transmission.
Old 09-23-2009, 11:30 PM
old76c10's Avatar
all jacked up on mountain dew
or he could swap all the wiring from the truck to the jimmy and use the computer from the truck and it would be free just time consuming
Old 09-24-2009, 10:45 AM
fast68's Avatar
likes chevy trucks & boobies
i dont understand why ppl have such a hard time understanding that the 4L60E is electronically controlled and needs the PCM to operate and will not readily work in place of a non-E trans
and think they can easily do it
crazy,,
it seems like every day theres a dozen ppl starting threads thinking they are going to put an E trans where a non-E trans was..
wow..
so much fail..
i dont know within how many different threads you have to tell ppl it wont readily work and will require money or lots of work before ppl will finally quit starting the same new threads asking if they can do it or not..
hmm..
700r4 to 4L60E swap chevy_c10 Transmission - Rearend 19 05-10-2009 08:30 AM
700r4 and 4l60e jadejoky28 Transmission - Rearend 4 04-01-2009 08:18 PM
700R4 to 4L60E DR132 Transmission - Rearend 2 08-20-2008 08:31 PM
93 4l60e to 89 700r4 questions Bumper Thumper Transmission - Rearend 4 06-06-2007 01:07 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 03:34 AM
