Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $5,528.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-17-2005, 03:50 PM
martinr martinr is offline
4L60E and 700R4 similarities
Let's say you wanted to convert your LT-1 engine out of a '95 Camaro to carb and rear position distributor and get rid of the computer. Is there a way to get the 4L60e to work with this engine configuration or would you have to go to the 700R4? Will the 700R4 bolt up to the LT1? What is needed to make this swap?
Old 12-17-2005, 04:23 PM
37ford4dr's Avatar
37ford4dr 37ford4dr is offline
bobs77vet
bowtie overdrives is a great resource
www.700r4.com
Old 12-17-2005, 07:35 PM
Crosley's Avatar
Crosley Crosley is offline
Streetbeasts lawsuit donor
Crosley's barnstar
Wiki editor
Last wiki edit: T-700r4 though 4L70E tips and tricks
Wiki Edits: 874
Non computer controlled 700 / 4L60 will bolt to the engine.
The 4l60E needs a computer to control pressures & shifts..... or convert the 4L60E to full manual shift with vacuum control main line pressure
At the Bonneville Salt Flats... 130mph is known as First gear ..............
People have issues .. cars have problems
Old 12-18-2005, 08:55 AM
Thanks. Now . . .
Does this go for the flexplate and torque converter as well? Are they interchangable? What is the difference between a non-computer 4L60 and a 700R4? Which should I seek out? Now if I can just find someone who wants to swap!!!
Old 12-18-2005, 09:16 AM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 874
Make sure you have the correct flexplate for the engine. The bolt pattern for the converter will bolt to any 700 / 4L60 converter for V8's. 3 piece 4L60/65E trannys use different converter bolt pattern( bell housing unbolts)
the V8 style 4L60 and 700 are the same. the converters are the same , the flex plates bolt pattern for converter are the same. All bolts are still metric. 700 trannys have always been fully metric.
there are minor differences in 700r4 & 4L60's, but they all interchange parts. Later design parts are better. Some valve bodies & separator plates do not inter change from late to early design
700r4 name was changed to 4L60 when GM updated several areas of the trannys. Parts are basically the same.
GM updated listing names on the trannys ; 4L80E , 4T65E , etc.
4L60E & 65E are different in several areas from the non "E" units.
The 3 piece 4L60E tranny case design is different again. Different pump stator , converter design is different.
Early 700 pumps and stator parts must be watched for mis-match. You will have little or no pressure with mismatched parts of early pump / stator designs.
I hope that is all. If not someone will speak up I hope
Old 12-18-2005, 09:46 AM
Excellent info!
So, keep the original flexplate on the engine to avoid balancing problems and the converter and bellhousing from the 700r4/4l60 will bolt right up to the engine? Sounds too easy!! Am I missing something?
Old 12-18-2005, 02:48 PM
Crosley's Avatar
Crosley's barnstar
Wiki editor
Wiki Edits: 874
You will need the TV cable hooked up and ajusted correctly for the non "E" 700 style tranny.
Old 12-18-2005, 03:07 PM
mike 96 ws6's Avatar
mike 96 ws6 mike 96 ws6 is offline
Crosley covered a bunch of stuff I didn't know but I'll add a little from the little I know.
The 93 LT1 F-body's used the 4l60 / 700r4 transmission. You will need a throttle body from this year f-body which has the proper hardware to utilize the throttle valve cable used on the 700 and 4l60. Gee I just happen to have a stock 48mm TB I bought in order to convert my 96 to 700r4, although I ditched that project in favor of the increased control ability via PCM programming offered by the 4l60e. If you pursue this project I can sell you the TB for what I paid for it if you like.
I believe all the converters will interchange from 700's somewhere around 1987 when the 700 got a 30 spline unit { previous years 700's had a different spline that won't work} until 1997 4l60e intergrated case / bellhousing units. I have no Idea about 98+ f-body units.
I believe the PWM controlled 4l60e units started production in f-body's sometime during 95. There is a problem with installing a converter from a pre-PWM unit into a PWM configuration due to TCC apply properties vs lock-up clutch friction material design {although it worked fine for me temporarily}, but using your 95 converter should work fine in a 30 spline 700 / 4l60.
Your 95 VSS sensor will need to be adapted to the older tranny. This will require installing the 95 stator onto the 700 / 4l60 output shaft and installiing the 95 tail housing onto the older tranny since the VSS mounting configuration is different than the speedo cable drive type. You'll need the tail housing from your 95 anyway since the boss for connecting the torque arm will likely not be on the replacement tranny tail housing.
There seems like something else I'm forgetting. If I remeber what it is I'll post it. All this is info I collected in order to swap mine, but since I did not pursue that project, some of it may not be correct. Just trying to give you some idea of things to look for.
One other thing:
I built a bunch of carbed cars in my years, but this 96 trans am is the first fuel injected project I've gotten into. I haven't done a lot, yet, but I already see that I can make more power, run faster and get better gas milage with FI than a carb motor. These are some things I considered when I ditched my 700r4 project. I won't go back to carbs now.
Why the carb on your 95 FI f-body?
Just curious. Have fun!!!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "4L60E and 700R4 similarities"
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 07:16 PM
700r4 and 4L60E hotrod66_57 Transmission - Rearend 5 09-14-2005 02:34 AM
700r4 and 4l60e silm man Transmission - Rearend 9 09-02-2005 06:47 PM
700R4 with Vortec Computer Controlled Engine capps Transmission - Rearend 2 07-30-2005 01:17 PM
Clueless 4L60E question bluesman123 Transmission - Rearend 2 08-02-2004 08:59 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
